i order from you 2 powermax plus they just arrived thank you
i would like to ask you if you know
1. how can i set a PIR( zone 3) always bypass at the night? i want to press the button on the keyfob and set it bypass I can not find the instraction in the manual)
2. how can i setup the 4th key on the keyfob * ?????
3. witch pir with cable can i take from your store to use it with powermaxplus?
4. witch internal sirin with cable can i take
Program the zone as an 'Interior' type. These will auto be omitted when armed in home mode (part set)
You can change it from a status button but what do you want it to do?
Any of the hardwired sensors. What environment are you putting it in?
http://www.securitywarehouse.co.uk/catalog/elmdene-int500s-internal-sab-p-610.html
