Secware Posted November 30, 2011 Posted November 30, 2011 Hi, I have the ADE honeywell accenta mini gen 4 with LCD keypad and as second pad I have the Simple Set Reader.Can I buy the ADE Infomaer speech dialler and use it on this hardware? I also want to buy a 16ohm internal speaker. Now I have set 2 programms, 1 for in the day when we are going (every PIR is on) and 1 for night use (all PIRs are on downstars but upstairs they are off). Now my Simple Set REader is upstairs, how can I program it that only program2 for night is on when I go with the FOB on the pad? Thanks Quote
Secware_Tech6 Posted December 1, 2011 Posted December 1, 2011 You cant partset from the simple set reader. There isnt a way on that panel of doing it via gobs im afraid. You can use an informa and the accenta has dedicated comms outputs so you can signal alarm, fire, pa etc seperatly if required. You can connect a 16 Ohm speaker to the panel Quote
