October 25, 201114 yr I am interested in your product 21/40, Secware Anti Vandal Low Light Fixed VF Dome Camera. However, there is little detail on the website, and Cat 5 is mentioned. Can you please tell me whether this is a standard analogue output camera, or network output with configuration via Ethernet? Thank you,
November 1, 201114 yr need a model number to be sure (the 21/40 just shows the number of products in the search or catagory you were in) But im assuming its the secware pro unit and as such is an analogue unit. You can use cat 5 if you use baluns to convert the signal. It is not an IP / network camera
