Secware Posted October 17, 2011 Posted October 17, 2011 is it possibe to part set a system, silently, using a Honeywell easy set with key fob. If not , how is this acheived. I want to set/ unset the ground floor from the first floor, in the quickest and quietest way. Quote
Secware_Tech6 Posted November 1, 2011 Posted November 1, 2011 You cant partset on a simple set. It allows full set and unset only. Depending on your panel you can configure the output on the simple set and connect it to a keyswitch input zone Quote
