last year bought Honeywell ADE LCD Accenta from you website want to add:
Honeywell Hard Wired Carbon Monoxide Alarm
Honeywell Combination Optical/Thermal Smoke Detector (58°C~)
Honeywell Combination Rate-of-Rise/Thermal (58°C)Smoke Detector.
are the above compatible and do I need bases for the fire detectors and can I add a 12Volt 7Ah battery instead of the 2.3Ah exernally (outside of the panel)
All three Honeywell fire sensors are compatible with the ADE Accenta control panel but will need either a latching or non latching base.
Although you can add a 7A/h battery I do not reccommend it as the panel would struggle to charge it when fully depleted, and being outside the panel it is not tamper protected and thus could be removed.
  • 4 weeks later...
