Secware Posted August 26, 2011 Posted August 26, 2011 The wiring diagram suggests that for multiple keypads, the wiring should be serial i.e. from alarm panel into the first keypad then onto the second. My question is can I wire each keypad back to the alarm panel independantly (in start wiring), e.g. the comms connection at the alarm panel has two wires comming from it, one to the first keypad and one to the second keypad. Quote
Secware_Tech6 Posted August 26, 2011 Posted August 26, 2011 Yes you can use star keypad wiring on this panel Quote
