have wired up system as should be, have all cct returns, bell tamper, PA and global tamper returns as should be.
But on powering up all the RKP is showing is software version 4.00.
Have depowered and shorted out NVM & kick start pins and tried again but just stays the same.
It sounds like you have either a wiring issue on the data line to the keypad or a cable fault.
To test use a short length of cable and wire the keypad directly to the panel.
It could also be an overload issue what is your day mode current?
