May 31, 201115 yr Hi, I've had the above system fitted by ADT (it has the LCD radio keypad) and I was checking to see if your gray tags should work - that is, would ADT manage to disable tag use and programming on their equipment. They have already quoted a silly price for the radio tag (
June 4, 201115 yr The whole package looks like your product: Honeywell Domonial Wireless 2 PIR Kit 2 (without the grey tags).
June 8, 201115 yr The Honeywell tags work with Honeywell equipment, but will need programming in, to use the plastic tags you will need a tag reader either as an addition or built into your keypad. As you have mentioned radio fobs, I am unsure you will have a reader in your system, please check to ensure you do before thinking of using these tags
