nealjane Posted March 24, 2009 Share Posted March 24, 2009 how do i clear an error - it states z03 alarmed - living room and says 'alarm in memory'. i also have a s01 tamper/open error [its the back pin i think - box is fixed back to pebble dash wall and the pins clearly not pushed in.] - not sure if it can be adjusted - instructions arent that clear... if i sort out the external box, will this then clear the issue/problem i have with the living room and allow me to set the alarm?? Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted March 30, 2009 Share Posted March 30, 2009 yes i would suggest it is due to the pebble dash. There is an adjustment screw on the rear of the unit for the rear tamper. You will need to adjust this until the button is pressed fully in when fitted to the wall. Easist way to remove the 'alarm in memory' is just to set the system (ie leave the property and arm in the normal way) then unset. Any previous alarms will then be reset. SUpport Quote Link to comment Share on other sites More sharing options...
elund Posted July 15, 2010 Share Posted July 15, 2010 I am also not able to clear an error that states that a zone is alarmed. Easist way to remove the 'alarm in memory' is just to set the system (ie leave the property and arm in the normal way) then unset. Any previous alarms will then be reset. What exactly do you mean be setting and unsetting the system? Don't know what you mean with leaving property and arm in the normal way. Thanks in advance, Elund Quote Link to comment Share on other sites More sharing options...
accounts3 Posted July 15, 2010 Share Posted July 15, 2010 Hi Elund Set the system, leave by the normal exit route, shut the door and allow the system to set,( = arm in the normal way) open door, re enter and unset the alarm = setting and unsetting the system Hope this answers the query Anne Quote Link to comment Share on other sites More sharing options...
elund Posted July 15, 2010 Share Posted July 15, 2010 Hi Anne Thanks for the prompt reply :-) I am not able to set (arm) the system because of the alarm in memory. So I guess I have reset my PowerMax Pro to the factory default parameters? Best regards, Elund Quote Link to comment Share on other sites More sharing options...
elund Posted July 15, 2010 Share Posted July 15, 2010 Sorry I had overlook an alarm - probably caused by a defect MCT-303 Shock Sensor. I have now deleted the MCT-303 from the zone. Now I am able to set and unset the system and the other alarms have been deleted :-) Thanks for you time, Elund Quote Link to comment Share on other sites More sharing options...
