Heavenr Posted February 18, 2009 Posted February 18, 2009 I have replaced an old Optima panel, (18 years old) with a new Optima Compact. All works fine except the LED in the PIR does not flash like they used to when I walk into a room and the alarm is not set. You can still hear the relay click in the PIR. Only the panel wiring has been touched. Any suggestions what to check as I have already checked the wiring, or does the new Optima panel work slightly different than the old one. Robin Quote
Secware_Tech6 Posted February 19, 2009 Posted February 19, 2009 unless you are disableing your leds remotely that is not a function of the panel etc. SUpport Quote
ravis94 Posted May 1, 2009 Posted May 1, 2009 Are you sure that the aux power is connected and not being shorted along the line? Quote
