August 29, 201016 yr Hello I have managed to obtain a copy of Wintex(v5) and the Veritas UDL. I've read that Wintex can also allow the programming of the veritas excel. Is this true? I can't find the option under "account" that allows you to choose a veritas; the list just has the premier systems... With the Veritas UDL am I required to buy a texecom PC-COM? Can't I just make my own RS232 using the tx rx and 0v (pinout 2 3 5 on the rs232) Can you please tell me whether or not I can build my own cable?
September 23, 201016 yr im sure you can build your own, but its not semething i have done. I do recall the excel having udl options in the past not sure if that still relevant. The premier is defienetly fully supported via wintex.
September 26, 201016 yr Author Thanks. I'm going to have a go... I will let you know if it works! If not I will look into buying the pc com!
