That PIR wont work on your existing receiever. You will either need a newer reciever or a powermax plus control panel.
Id be concerned using any movement sensor in an area with high animal movement. To a point it will be function, but any movement detector will false alarm occasionally in that environment. You might be better of looking at the optex units or active beams.
