joshward34 Posted July 29, 2010 Posted July 29, 2010 Hi all Looking to purchase a wireless alarm for my house. 5pir's, 1 contact, panel. Would like to use existing wired bell box if possible. A good battery life would also be nice. Been looking at the infinite prime alarm, and the visonic powermax kit. The Scantronic 500r also looks ok Only problem is that the powermax plugs in with a plug in transformer, wouldn'y that be easy to defeat by a burglar? Any advice would be great Thanks Josh Quote
Secware_Tech6 Posted July 29, 2010 Posted July 29, 2010 In what way? If you mean it can be unplugged then yes it could. But you shouldnt plug them in anyway. They should be hard wired into a spur. But any proper panel has battery backup so if your burglar unplugged it he would have to waut a minimum of 12 hours for the panel to go flat. Then if your remote signalling the panel would send a low battery before dying. If its audible only the sounder would sound once the panel died. All that assumes it installed and configured correctly Quote
joshward34 Posted July 30, 2010 Author Posted July 30, 2010 In what way? If you mean it can be unplugged then yes it could. But you shouldnt plug them in anyway. They should be hard wired into a spur. But any proper panel has battery backup so if your burglar unplugged it he would have to waut a minimum of 12 hours for the panel to go flat. Then if your remote signalling the panel would send a low battery before dying. If its audible only the sounder would sound once the panel died. All that assumes it installed and configured correctly The powermax comes with a plug in transformer though, so i presume you couldn't wire it in to a spur like you suggested. I presume with the infinite and 500r you can wire them in directly though? Quote
Secware_Tech6 Posted July 31, 2010 Posted July 31, 2010 The powermax comes with a wall mount transformer. The powering (mains) is flying lead. So yes you can direct into a spur or fit a plug and plug it in. Quote
joshward34 Posted August 1, 2010 Author Posted August 1, 2010 The powermax comes with a wall mount transformer. The powering (mains) is flying lead. So yes you can direct into a spur or fit a plug and plug it in. I never knew that! How big is the transformer then? Quote
Secware_Tech6 Posted August 2, 2010 Posted August 2, 2010 Same size as a normal brick, but wall mountable instead of being the plug in variety Quote
