securitywarehouse Posted July 21, 2010 Posted July 21, 2010 Just purchased a host of intruder alarm equipment from you - it arrived yesterday. The control panel is the Texecom Premier 48. Does this panel have an intergrated sounder that will sound when the alarm is activated (entry/exit and on activation) or do I have to buy something additional? Quote
Specialist1 Posted July 23, 2010 Posted July 23, 2010 Hi: Looking at the Installer Manual it shows that the panel can drive either 1 x 16ohm or 2 x 8ohm speakers in series, these being wired across the spkr+ & spkr- terminals. Unfortunately as with most panels nowadays the speakers don't appear to come with it. Hope that helps: Andy @ Amman Security Quote
Secware_Tech6 Posted July 29, 2010 Posted July 29, 2010 agreed. It will require an internal sounder. Id use the secware 16 Ohm speaker Quote
