securitywarehouse Posted July 13, 2010 Posted July 13, 2010 I have a domestic Itec Horizon alarm system with shock sensors wired on every window and door sensors on the front and back door. The systen does not use PIR's. The main Horizon box has developed a fault and I understand these are quite old now and no longer available. Can you tell me what a modern equivalent system is that would be compatible with the existing installation - ie the window and door sensors and the price? Quote
Secware_Tech6 Posted July 14, 2010 Posted July 14, 2010 Depends on the sensors you have. What vibration sensors do you have now, and how many detectors in total is there? Quote
securitywarehouse Posted July 16, 2010 Author Posted July 16, 2010 Hi there, many thanks for your response. [Depends on the sensors you have. What vibration sensors do you have now, and how many detectors in total is there?] The vibration shock sensors have 'Itec' written on them, white in colour and are approx 2cm x 2cm x 5cm. There is no other writing on them - I can send you a photograph if it helps. The house is fitted with 12 of the vibration shock sensors with 2 door opening sensors. Thanks again for your help. Regards Quote
FastCar Posted July 16, 2010 Posted July 16, 2010 IIRC a few alarm panels ( Itec , Scopetronic Homeguard etc) had a zone type called Inertia or similar and had pulse count and gross attack settings.This allowed non-powered shock sensors to be used (basically just a device with a cup and ball or similar).Some had a separate analyser card fitted within the panel.Either way I think you may struggle to find a panel compatible with your particular shocks ( they may also have degraded , especially on windows with condensation). Quote
Secware_Tech6 Posted July 16, 2010 Posted July 16, 2010 Yes a picture would help. As fastcar states some panels do have built in analyser zones, but you may have relay based vibration units. If so no analyser is needed. Quote
