securitywarehouse Posted June 29, 2010 Posted June 29, 2010 I am tring to select an alarm with the following requirements: Up to 8 zones LCD keypads (1) Proximity tag capability (prefer it built into the keypad) Easy to use Autodialler capability preferred but not essential (can add standalone autodialler) Reasonable cost The panel will be in an obscure location which wont be accessed regulary (no need for buttons) so will be controlled/programmed by remote keypad/fob Please advise which items would be suitable Quote
FastCar Posted June 29, 2010 Posted June 29, 2010 Reasonable cost?..have a look at the MDT Avanti http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&cPath=36_41&products_id=995 LCD keypad with prox Quote
Secware_Tech6 Posted June 30, 2010 Posted June 30, 2010 as fastcar says, mdt or alternativly a scantronic 9651 with prox keypad. Quote
energysolutions Posted June 30, 2010 Posted June 30, 2010 Thanks for the replies Both seem good and I will investigate each before making a decision Is the MDT really as easy to programme/operate as the manufacturers would suggest? I have only really worked with Texecom products up to this point (Veritas 8/R8) and know them quite well, how do these products compare ie reliability, ease of use, how hard to set up etc etc Thanks in advance Quote
Secware_Tech6 Posted June 30, 2010 Posted June 30, 2010 very similar. but if you have experience with one brand that will be easier than anything else Quote
energysolutions Posted June 30, 2010 Posted June 30, 2010 I`m leaning towards the MDT - are the manufacturers claims accurate that: There Quote
energysolutions Posted July 1, 2010 Posted July 1, 2010 And are these claims accurate in the real world? There Quote
energysolutions Posted July 1, 2010 Posted July 1, 2010 This is probably a daft question but I assume that the alarm can be set/unset via inputting a 4 digit code into the keypad as well as the proximity fob? Quote
energysolutions Posted July 1, 2010 Posted July 1, 2010 Thanks for that Is it possible to purchase the panel with 2 x prox LCD keypads ie Upgrade the included keypad to a LCD prox and purchase a second I dont want/need a non prox keypad Quote
Secware_Tech6 Posted July 2, 2010 Posted July 2, 2010 I can see if we can do a kit like that. Id assume we could. Leave it with me. Quote
energysolutions Posted July 2, 2010 Posted July 2, 2010 I can see if we can do a kit like that. Id assume we could. Leave it with me. Sounds good - thanks very much! Quote
energysolutions Posted July 5, 2010 Posted July 5, 2010 I can see if we can do a kit like that. Id assume we could. Leave it with me. Hi, Did you find out if it was possible to purchase a panel and two prox keypads as a kit? Thanks Quote
