securitywarehouse Posted June 17, 2010 Share Posted June 17, 2010 How do you loop wire two Honeywell Intellisense IS215TCE PIRs into one zone when using a ADE Honeywell Accenta Metal Gen4 control panel? Quote Link to comment Share on other sites More sharing options...
FastCar Posted June 17, 2010 Share Posted June 17, 2010 Its poor practice to put 2 pirs on one zone , but if you must , put the alarm contacts in series.Wire both detectors back to the panel , then take a wire from each pir relay , join together , this will leave you with 2 wires , connect these into the zone terms. Quote Link to comment Share on other sites More sharing options...
SafeNet Posted June 18, 2010 Share Posted June 18, 2010 If you have to ask this question... don't open the control panel... pick up the phone and call someone to do it for you... who knows what they're doing.. but if you must DIY turn off the mains first..before opening...only power up when you've replaced the front... come on people HSE is watching !!! Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted June 30, 2010 Share Posted June 30, 2010 Both valid points. I wouldnt advise putting more than 1 detector on a zone. Quote Link to comment Share on other sites More sharing options...
