[Ticket Question] Problems with a Texecom Bell Box
securitywarehouse
In november i bought a texecom bell box off you and its just stopped working. the rest of the alarm is functioning fine. when enter the eng code, the 05,54321 to test the sounders everything except the bell box works. it was working fine, so could i return it please unless you can suggest something to try? all the wires inside are firmly connected.
  • 2 weeks later...
If it is faulty then you can return it. But id verify it is indeed faulty before sedning it back.
As above id check that the tamper switches are closed, that the sabt is correctly wired into the panel, and that you have a voltage on the bell trigger (0v) when the bell shoudl be activating
