June 7, 201016 yr Need external apir sensor with dc input, adjustable on/off times, 180 degrees+ range. Which is suitable.
June 7, 201016 yr 12v dc? id so the only unit that will do 180 degs is the voltek twin head. But this doesnt have adjustable times etc. Apart from the opal elite (gjd) none have a programmable time this is usually done by the controller
June 8, 201016 yr Author Is the opal elite suitable ? Requires 180 degrees+, 12/24Vdc, adjustable times, exterior use.
June 8, 201016 yr its not 180 deg, i dont know of a single head pro unit that is. Its usually only the low qualioty stuff that is. but it is 12v, with adjustable times etc Have a look at the product page download the data sheet
June 20, 201015 yr Depending what you're wanting it for... the Optex BX-80N has 180 degree upto 24mtrs (12mtrs each way)...if it's for security or camera's.. probably not much good for lighting though.. There's even a battery version... Not sure if it's allowed, Admin please remove if not, but the website gives more info www.optex-europe.com and search BX-80N.
June 30, 201015 yr the bx 80n has 2 detectors at 180 degrees, but it wont cover 180 degs. The only unit i know of is the voltek 1811 http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=1533
