securitywarehouse Posted May 25, 2010 Posted May 25, 2010 Now that I've replaced the old Optima with the new Optima 2 lanel, I'm now trying to swap the old sensors with the pet friendly Active8 PIR models. However, new sensors have: 1: EDL (single connection) 2&3: Tamper (double connection) 4&5: Relay (double connection) 6: EOL (single coneection) 7: 12v + 8: 12v - Two of my old sensors have: N/C Lt Blue then Yellow Propose: Relay 4&5 + Red Propose: 12v + 7 - Black Propose: 12v - 8 24hrs Lt green then white Propose: Tamper 2&3 My remaining sensor has: Alarm Lt Green then White Propose: Relay 4&5 + Red Propose: 12v + 7 - Black Propose: 12v - 8 Tamper Empty and Empty Please could you confirm that my proposals are correct? Or make corrections where necessary. I am extremely grateful for the support you offer. Many thanks, Quote
Secware_Tech6 Posted May 30, 2010 Posted May 30, 2010 yes you right however you will need to tamper the other detectors Quote
