securitywarehouse Posted May 19, 2010 Posted May 19, 2010 I have problem where the dialer will dial out when made to do so through test setup/Engineer mode no problem but doesn't dial when the alarm is activated. Is this Informa faulty? Quote
rbrewer Posted May 19, 2010 Posted May 19, 2010 This is my ticket... also noticed this post with similar problem. http://www.securitywarehouse.co.uk/forums/index.php/topic,367.msg1043/topicseen.html#msg1043 But no solution at end of thread... R. Quote
securitywarehouse Posted May 19, 2010 Author Posted May 19, 2010 Please give our Technical Staff time to look at your ticket and answer your query. The link you have provided was not concluded as the member didn't respond to our Technical Staff. We will be happy to sort this matter out for you and if Technical deem the item to be faulty, append a message to your original ticket, check the reopen on reply box and send it back to us. We will then pass the ticket to our Returns Team, who will organise a replacement for you. Quote
Secware_Tech6 Posted May 21, 2010 Posted May 21, 2010 Best thing to do is can you upload of a pic of both end wiring. ie the panel and the com. THis is usually a wiring issue as the trigger isnt getting to the dialler Quote
