Can anyone send me any manuals you have for the non addressable Rafiki fire alarm systems and any other information you have on max loadings and cable lengths etc..
Can you use 4 core cable to add additional devices? Do they do a remote LED? Can you use the output module on the zone? Is the repeater fully functional i.e can you silence reset etc
Does it meet EN54 standards? How much warrenty do you get? What DB level do the sounders in the call points kick out? What is the hatari sounder used for? Sorry for all the questions but we are possibly going to change from the equipment we usually use and want to no what the panels are capable of.
Neil
The rafiki system is a 2 wire system. Id advise you have a good read through the system spec sheets but
All devices sit on the 2 wire zone cable. This allows relay modules, sounders, call points, smoke detectors etc to be on the same cable.
Yes
Yes
Does it meet EN standards?
Yes
Upto 85db on High
As a stand alone higher output sounder
