Posted
Hello, I have just installed an Accenta G4 mini.
when I do a walk test all door contacts come up 1 and all PIRS show 0 until they are ch3cked and when they are they show 1 as expected.
when the alarm is set it shows setting Fault at front door .
The G4 mini was a replacement for my G4 metal and both wiring diagrams are the same .
can anyone advise what the problem maybe
thanks
Posted
Look slike a problem with circuit 1
Have you metered it is the contact closing as expected what is the resistance reading when the door is closed.
Why was the previous panel replaced but also bear in mind the g4 has been out of production for a while are you sure you have a brand new panel?
Posted
Hi there thanks for your reply, yes the contact works fine when metered and the door is opened and closed .
it is a new panel and on looking online it seems to be a common problem
  • 3 weeks later...
