John693 Posted July 12, 2024 Posted July 12, 2024 Hello, I have just installed an Accenta G4 mini. when I do a walk test all door contacts come up 1 and all PIRS show 0 until they are ch3cked and when they are they show 1 as expected. when the alarm is set it shows setting Fault at front door . The G4 mini was a replacement for my G4 metal and both wiring diagrams are the same . can anyone advise what the problem maybe thanks Quote
Secware_Tech6 Posted July 12, 2024 Posted July 12, 2024 Look slike a problem with circuit 1 Have you metered it is the contact closing as expected what is the resistance reading when the door is closed. Why was the previous panel replaced but also bear in mind the g4 has been out of production for a while are you sure you have a brand new panel? Quote
John693 Posted July 16, 2024 Author Posted July 16, 2024 Hi there thanks for your reply, yes the contact works fine when metered and the door is opened and closed . it is a new panel and on looking online it seems to be a common problem Quote
Secware_Tech6 Posted July 17, 2024 Posted July 17, 2024 It's not a common problem I know of. If you loop out the circuit what happens then Quote
John693 Posted August 5, 2024 Author Posted August 5, 2024 Hi there, is still showing up as a 1 Quote
Secware_Tech6 Posted August 7, 2024 Posted August 7, 2024 if the circuit is looped out and showing as active (with no other wires connected to the terminals) id suspect a panel issue. Quote
Secware_Tech6 Posted August 7, 2024 Posted August 7, 2024 i assume it also shows this when trying to arm the system? Quote
