securitywarehouse Posted May 7, 2010 Posted May 7, 2010 I have a Simon3 alarm 433mhz and was wondering if your advertised sensor (Risco wisdom wireless door sensor 433mhz sensor)will work as a replacement and should the simon3 alarm learn this new sensor? Quote
Secware_Tech6 Posted May 7, 2010 Posted May 7, 2010 I would say no. pretty much all rf gear is system specific, ie you need a risco transmitter for a risco reciever. the only thing I can suggest is to use a universal reciever and connect that to your panel. assuming of course your panel has hard wired inputs available. James Quote
