May 7, 201015 yr Do you supply a vandal resistant keypad that has either a USB or RS232 interface. USB is preferred. I think that the Storm 1000 keypad does have an RS232 output. Can you confirm this,and could you get stock of this item if you do not already ? Thanks in advance.
May 7, 201015 yr I dont think any of our units do. Do you want to connect this to a pc and your own software?
May 10, 201015 yr Author Yes I need to connect the keypad to a computer that has an RS232 connector. And yes I have written some simple software myself to achieve an access control solution that uses several technologies at once.
