can you give me the dimensions for the above lock? Is the .9 amp a peak current as il be using the 1 amp elmdene supply?
Also is it designed for recessing like normal solenoid locks (ie not a magnetic lock which is bulky) I want to recess it into door frame directly above door centre.
Yes you can flush mount it, and thats what its designed for. As far as i know there isnt aq surface housing for it.
I would always recommend using a bigger psu than 1A for the system and locking. its a bit close but in theory should be fine.
