securitywarehouse Posted April 29, 2010 Posted April 29, 2010 I plan to buy an Optima Gen 4 security panel and would like to know what size battery/part number this unit takes so that I can order this at the same time. Quote
Secware_Tech6 Posted April 29, 2010 Posted April 29, 2010 The optima is now only available in the 'compact' enclosure. While the panel is caperble of a much larger battery the case will only accomodate a 2.1-2.4 A/h battery eg. http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=1339 its a physical size restriction and any suitable battery with these dimensions will be fine. James Quote
