Secware_Tech6 Posted February 20, 2024 Posted February 20, 2024 Hello, I'm hoping you can assist with a product enquiry. I'm looking for a device to detect the start of a lithium battery fire. I'm keen for advice on if heat and/or smoke is best for this use case. The power available is 24v DC and I'm hoping the sensor will have either a repay or some sort of output I can connect into a monitoring PLC. many thanks, Quote
Secware_Tech6 Posted March 24, 2024 Author Posted March 24, 2024 the issue here is the actual type of fire. An optical smoke detector can detect smoke and then a relay base will provide your relay for interconnection. However most are 12v you may need to use a power converter to drop to 12v dc from 24 Quote
