Nhoj Posted March 29, 2010 Posted March 29, 2010 Was wondering if anybody has detail for the Scantronic Plug-in footprint used by the 960? I wanted to hook this speech dialer up to an alarm that does not have the Scantronic footprint. If I could get hold of the spec for the two connectors of the 960 I could then jury rig a connector (or spade terminals) to tease out the 4 standard triggers as well as the line fail signal. I could also take care of any other inputs that need to be dealt with. Any ideas? I've done an extensive web search for detail of the footprint but have not found anything. Thanks John Quote
Secware_Tech6 Posted April 14, 2010 Posted April 14, 2010 most plug on comms use a 5v as well as a 12v supply. Do you have 5v available? Quote
