May 28, 20215 yr I have an Infinite Prime Alarm System installed. The alarm system has a PSTN module which I want to setup.I intend to run a two wires (blue/white and white/blue) from the master socket to the micro filter marked ‘from VDSL Line’.The two ‘OUT’ wires marked ‘To Modem’ would go to the two terminals on the PSTN module. Is this correct?Is the PSTN module performing like a modem? I do apologise for my lack of ignorance regarding the function of a PSTN module.Thanks
May 29, 20214 yr Yes that looks correct, however be careful with UK bt lines as they are changing to an ip core
