Secware2 Posted May 28, 2021 Posted May 28, 2021 I have an Infinite Prime Alarm System installed. The alarm system has a PSTN module which I want to setup.I intend to run a two wires (blue/white and white/blue) from the master socket to the micro filter marked ‘from VDSL Line’.The two ‘OUT’ wires marked ‘To Modem’ would go to the two terminals on the PSTN module. Is this correct?Is the PSTN module performing like a modem? I do apologise for my lack of ignorance regarding the function of a PSTN module.Thanks Quote
Secware_Tech6 Posted May 29, 2021 Posted May 29, 2021 Yes that looks correct, however be careful with UK bt lines as they are changing to an ip core Quote
