Secware2 Posted March 26, 2021 Posted March 26, 2021 Can you please advise which model of your product is suitable for the following application? CCTV IP camera triggers alarm output when motion is detected using a dry contact (open or closed options with the camera settings are available) I am look for a suitable dry contact trigger relay which would switch on a 12V LED light (max Load less than 10A) Ideally if there is a potentiometer timer built in for the 12V output , but without is ok too. Quote
Secware_Tech6 Posted March 26, 2021 Posted March 26, 2021 Something like this? Precision Timer Relay Quote
