Secware2 Posted March 25, 2021 Posted March 25, 2021 Homelink 75 panel – before you despatch it would it be possible for me to speak to someone for advice? My panel currently runs for about 3/4 hours and then dies. When I replace the rechargeable batteries it’s fine again and when reconnected to the psu it appears to be running from the mains supply – can these psu’s repeatedly fail over the course of a few hours under load? Quote
Secware_Tech6 Posted March 25, 2021 Posted March 25, 2021 I'd check the output of the psu when it's OK and when failed. That will confirm if it's the psu. It could also be overloading if something is taking too much current. Again multimeter will confirm Quote
