Secware2 Posted January 11, 2021 Share Posted January 11, 2021 Hi guys, I’m curently using a couple of Texecom RF 360 PIR sensors (from your good selves). I’ve had them in place for several years covering some common hall/landing areas, all good. Last year I got a cat… Even on pulse count=2 these sensors are not pet immune, and as a result I’ve had to stop arming the alarm, otherwise the cat will set off false alarms all the time. ? I need to stick with 360 ceiling mounted sensors as the wiring is in place inside a finished ceiling. I have a little void, so I could potentially change from surface to recessed flush mounting if necessary… Is there such a thing as a pet immune 360 ceiling PIR? would perhaps a dual-tech sensor work better for me? – like the DT version of the same Texecom sensor? Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted January 11, 2021 Share Posted January 11, 2021 I'm not a fan of pet sensors anyway but I'm afraid I don't know of a ceiling detector. You can of course use a standard sensor with ceiling bracket. The best way in any system with pets is peremiter protection not space protection Quote Link to comment Share on other sites More sharing options...
Pgordon Posted January 11, 2021 Share Posted January 11, 2021 2 hours ago, Secware_Tech6 said: I'm not a fan of pet sensors anyway but I'm afraid I don't know of a ceiling detector. You can of course use a standard sensor with ceiling bracket. The best way in any system with pets is peremiter protection not space protection Thanks, of course the system came long before there was any suggestion of pets... Do you think a dual-tech sensor might work better than just IR ? I'd not thought of putting a standard sensor in its place, - I'd no idea there were ceiling brackets for these sensors, but wouldn't the detection pattern be "off"..? Cheers Quote Link to comment Share on other sites More sharing options...
Pgordon Posted January 11, 2021 Share Posted January 11, 2021 I've been continuing searching, and I've found a couple that claim to be what I need: https://www.amazon.co.uk/OWSOO-Infrared-Microwave-Detector-Pet-Immunity/dp/B086KZLBHS/ref=pd_rhf_dp_s_pop_multi_srecs_sabr_0_7/261-3684634-4703540?_encoding=UTF8&pd_rd_i=B086KZLBHS&pd_rd_r=0c400fde-1f11-4439-a0f7-1e0b458ff418&pd_rd_w=x3VtB&pd_rd_wg=cAGmP&pf_rd_p=5864a8c4-0ac6-4e57-aa01-41e26a7ef9f7&pf_rd_r=Q17WB9KHH8YJ11XB6S1T&psc=1&refRID=Q17WB9KHH8YJ11XB6S1T or perhaps https://www.amazon.co.uk/Anti-Pet-Infrared-Detector-Security-Waterproof/dp/B07MZTYVBK Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted January 11, 2021 Share Posted January 11, 2021 I'd be cautious of those units as they don't seem to be meet 50131 They maybe OK I don't see a dt will help a movement sensor isn't intelligent enough to determine object size ie pet vs human crawling etc. Quote Link to comment Share on other sites More sharing options...
