MikeJ Posted November 3, 2020 Posted November 3, 2020 Hi All, I have a Pyronix V2 GSM dialler. Previously I could dial into the V2, enter the User Code, then enter the remote control menu. I have not changed any settings, but the User Code is now not being accepted when dialing in (the system voice just requests multiple times for a User Code to be entered, then it times out). I have checked: - The User Code still works when entered directly into the V2 using the keypad. - Status SMS messages are still responded to in the normal manner. Any suggestions as to what the problem may be? Many thanks in advance Mike Quote
Secware_Tech6 Posted November 4, 2020 Posted November 4, 2020 Hi Mike How are you dialling in, from a mobile or a landline? Quote
MikeJ Posted November 6, 2020 Author Posted November 6, 2020 Hi Secware_Tech6, I've tried both a mobile and landline. The V2 shows five signal bars (maximum). Quote
Secware_Tech6 Posted November 6, 2020 Posted November 6, 2020 I'd expect success with a mobile less so a land-line. Mobile on same network? Quote
MikeJ Posted November 9, 2020 Author Posted November 9, 2020 Hi Secware_Tech6, thanks for the reply. This problem is really frustrating me as I cannot see why it is happening. Some facts: Remote access was working until a few weeks ago. I had not changed anything when it then stopped working. Test message are still responded to in the usual way. I.e. both STATUS and INPUT 1 still receive a response. If the alarm is triggered the dialler does dial out, and pressing '5' appeared to acknowledge the call. I need to do it again to check, but it does appear to be 'listening' to tones. I haven't yet tried pressing 9 after pressing 5 to enter the remote control menu after alarm activated, but will do. This should tell me whether it is not accepting the User Code, or not listening to tones. The User Code does work when directly entered into the keypad on the dialler. I have tried changing the User Code, but it made no difference. I have checked that 'Remote Access' is enabled in settings I have tried calling from two mobiles on separate networks (Vodafone and Tesco/O2). No difference. The dialler has a Global M2M sim - multi-network so it may have changed network? Do you think that if it moved to a different network it may have caused this problem? Thanks, Mike Quote
Secware_Tech6 Posted November 10, 2020 Posted November 10, 2020 No I doubt its a network thing, there are issues and the team are seeing more with the pstn changes happening that's why I wondered if it was via an old line. Have you tried a payg sim on your network to test its not that that's the issue. Roaming sims are normally used for data not voice as I've never tested voice myself. Quote
MikeJ Posted November 19, 2020 Author Posted November 19, 2020 Hi Secware_Tech6, I have triggered alarm. Once alarm call acknowledged, I could then press 9 and enter the menu, and then move around the menu using key presses. So the V2 is receiving tones okay. Therefore I have narrowed the problem down to specifically entering the User Code - it works when entered directly via the keypad, but not when entered over the phone. I am out of ideas why this could be. Have you ever heard of this problem before? Thanks, Mike Quote
Secware_Tech6 Posted November 20, 2020 Posted November 20, 2020 No only on pstn lines. M2M sims dont tend to do voice so this could be an issue. Can you put a standard paygo sim in to test Quote
SimonM Posted May 17, 2021 Posted May 17, 2021 I have the exact same problem. It worked absolutely fine, then I did a factory reset, and ever since then I have been unable to access the user menu when dialling in, but pressing 9 after confirmation works. I haven't yet found a solution. Quote
