Secware2 Posted July 3, 2020 Posted July 3, 2020 Pyronix V2 GSM. I have 4 different voice messages on 4 different inputs. On activation of any input the first number is dialed, answered and accept code submitted.When the call is ended the dialer recalls three more times with the other three messages and the accept code has to be entered for all three.How do I stop the dialler making 4 calls for everyone alarm Quote
Secware_Tech6 Posted July 3, 2020 Posted July 3, 2020 how have you got this option programmed? Quote 5.8 DIAL ALL NUMBERS [173] If this function is enabled, all numbers programmed on each individual input will be dialled. Press the [ or ] keys to scroll to ‘DIAL ALL NUMBERS’ or enter ‘173’. Press t Press B or T to choose between Yes or No or select the number: 0 = No = Default 1 = Yes Press t Quote
