July 1, 20206 yr Hi I'm looking for a device to connect to a scientific freezer that will text/phone me if the freezer triggers its alarm. Ideally it should not require a landline. Can you advisse on which products I should consider please? Thanks
July 1, 20206 yr If its critical id recommend a polled device. A polled device checks its path is available and will report if the path fails remotely If its not critical then a gsm dialler will do some thing like https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/remote-signalling-c-36_57/menvier-sd3-speech-dialler-p-736.html
