June 2, 20206 yr Good morning, we are just finalising our new warehouse and need a beam system that can be put across the main shutter door that will play an audible alert if anyone enters the warehouse. Could you please advise what equipment we would require
June 3, 20206 yr id suggest an active beam connected to a basic control panel capable of 'chime' If these are the only requirements id look at the optima compact, takex beam and an internal speaker plus battery etc
