Secware2 Posted May 12, 2020 Posted May 12, 2020 Hi, my Siren for the pyronix enforcer MK2 is low battery. Is it simply swapping the old batteries out and no programming needed Thanks Quote
Secware_Tech6 Posted May 12, 2020 Posted May 12, 2020 assuming the device is programmed in correctly currently then yes Quote
