RLongdon Posted March 16, 2020 Share Posted March 16, 2020 Hi, Can anyone help. I have an Pyronix Enforcer alarm, all I want to do is edit Zone B. It currently sets downstairs in house and garage, I just want to edit it to set garage only, but can't find anything in the manual to help me do this, any help much appreciated, regards Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted March 16, 2020 Share Posted March 16, 2020 It's in the change zones menu Quote Link to comment Share on other sites More sharing options...
RLongdon Posted March 19, 2020 Author Share Posted March 19, 2020 Many thanks, I’ve just found it in the change input, scrolled to garage pir, select yes, it is set as “intruder” and then input area A and B are lit. I have changed the house pir’s that we’re on B to now only be on A. (Kitchen/hall) but I’ve just set zone B individually, and walked into garage, and the alarm does not go off. just also tested setting zone A, walled into garage, alarm did not go off then either. Anyone any idea’s why this may be? Many thanks Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted March 20, 2020 Share Posted March 20, 2020 If its in the area armed then it should activate. If using udl can you post the full program details I'll have a look Quote Link to comment Share on other sites More sharing options...
RLongdon Posted April 14, 2020 Author Share Posted April 14, 2020 Hi, not using udl. Now have another problem that the system won’t set at all. Utility pir which is the final exit (and was in zone b before I removed it) now not being picked up in a walk test. It’s set as “final exit” still, but fear I may have mucked something up when trying to get the garage to be on its own in zone b Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted April 14, 2020 Share Posted April 14, 2020 easy way to test the programming is to open the circuit connections on that device and see if the panel reports. If not it is programmed incorrectly Quote Link to comment Share on other sites More sharing options...
RLongdon Posted April 15, 2020 Author Share Posted April 15, 2020 I think I did that, well I took the cover of and changed the battery, and then it came up as tampered on the panel. So it is recognised my the system, just not “setting” when u walk past it it does not flash blue like the others. Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted April 15, 2020 Share Posted April 15, 2020 Is the battery seated correctly and the right way? Quote Link to comment Share on other sites More sharing options...
RLongdon Posted April 15, 2020 Author Share Posted April 15, 2020 Yep,,made sure when I changed it, I’ll double double check though Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted April 15, 2020 Share Posted April 15, 2020 id expect to see life from the sensor assuming the tampers are closed too. What does diagnostics say on that device from the panel Quote Link to comment Share on other sites More sharing options...
RLongdon Posted April 15, 2020 Author Share Posted April 15, 2020 Could you point me in the right direction to check diagnostics ? Quote Link to comment Share on other sites More sharing options...
RLongdon Posted April 16, 2020 Author Share Posted April 16, 2020 Yep, checked today and run battery diagnostics, all G’s Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted April 16, 2020 Share Posted April 16, 2020 ok. So as its responding on diagnostics it cant be programmed correctly. Are you allowing the device to settle after last detection before testing? You can cover it over if needed to prevent detection Quote Link to comment Share on other sites More sharing options...
RLongdon Posted April 18, 2020 Author Share Posted April 18, 2020 had another look today, changed a few settings, put utility pir as final exit for zone b, and now getting a response from pir/blue flash. But now zone a won’t set. So something still wrong. I’ll have another look around setting now that I’ve got used to what does what, otherwise I think I’ll have to get someone out. Some local engineers are a rip off, many seem to want £150 call out before they even touch it. Many thanks for your help though Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted April 18, 2020 Share Posted April 18, 2020 What's it coming up with when setting A Also re call-out charges 150 is about right for a non contract call-out, bear in mind it's their living. Dunno what you do but few people work for cost for long Quote Link to comment Share on other sites More sharing options...
RLongdon Posted May 24, 2020 Author Share Posted May 24, 2020 Won’t set zone a now. All seems to be in a muddle , looking like I’ll have to call engineer but many thanks for your help. Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted May 24, 2020 Share Posted May 24, 2020 Might be an idea. What is displayed when arming area A? Quote Link to comment Share on other sites More sharing options...
