We currently have a Karisma Plus wired system installed. There are 9 zones. It is getting creaky, I have repaired it several times, time for a change.
Our Ancient house is not good for wifi, so I want to stick with a wired system for reliability, using existing wires as these are hidden.
The Karisma uses a 3 wire id device, which made wiring and set up easy. Is there an equivalent today? Or what do you recommend?
Integrating fire detection / alarm would be useful.
Unfortunately Id is the bus system your panel uses is obsolete. If your a pro installer hkc make a bus system compatible with your wiring. If you have all 9 devices daisy chained then you can't use an eol type panel but if you have 8 core you can run 3 powered devices on each cable. Depends on the wiring
You can use Texecom Premier Elite with with Premiers Elite 60iXD expander. It's fully compatible with ID bus.
