May 25, 20196 yr i have paired my deltabell external sounder (see previous posts)problem i have now is whenever i enter my alarm code - the external sounder goes?when i do enter the codeit does bring up a message on the displayTesting....and then the standard now arming message...there is no alert about the external deltabell being triggered on the display panel and re entering the alarm code does not turn it off either. i have to access engineer menu and and exit and then it says 'saving nvm data' and it turns offproblem i have is i cannot set the alarm in either of my zones without the external sounder immediately going off?any advice on how i can fix this please?
