kyrusdemnati Posted May 17, 2019 Posted May 17, 2019 hey guys i have done a reset of my alarm system (had front door changed which affected tamper on door and i made the mistake of resetting entire system) so i am at step one and i am struggling to configure how it was before. i will try my best to give as much detail as possible. This is the setting at the moment. And i have put in red, the bits i am struggling with and trying to configure ZONE A/B (when leaving the home) (KITCHEN MOTION SENSOR) - MODE 06 INTRUDER (LOUNGE MOTION SENSOR ) - MODE 06 INTRUDER (BEDROOM MOTION SENSOR) - MODE 06 INTRUDER (UPSTAIRS LANDING) - MODE 6 INTRUDER FRONT DOOR MC1MINI-WE - MODE FINAL EXIT/TIMED (SO THIS COUNTS DOWN FROM 25 SECONDS AND WHEN I CLOSE THE DOOR THE TONE STOPS) However when i open the door, the system doesn't give me a countdown to enter my code to switch off the alarm? (it used to do this before) ZONE B (NIGHT) - so i want downstairs active whilst we are sleeping upstairs (KITCHEN MOTION SENSOR) - MODE 06 INTRUDER LOUNGE MOTION SENSOR ) - MODE 06 INTRUDER FRONT DOOR - WHAT MODE SHOULD THIS BE ON? i think i have set this as timed Other Questions I do have a bell box, but i need to get a ladder and learn the device again. What mode should be set too? My backlight display on the device, times out so its blank after setting an alarm how do i make this visible at all times? I want to add 2 more MC1MINI-WE to my set up in the near future Upstairs Window Back Conservatory Door what mode do i need to put this on? Other information From my front door there is no motion sensor in the path of the Main Panel to trigger the alarm, as its near the door. I wont be using my back door as an exit/entry route to arm/disarm the alarm if you need any more information, please let me know, i would appreciate your assistance to get this working? Quote
Secware_Tech6 Posted May 17, 2019 Posted May 17, 2019 2 hours ago, kyrusdemnati said: However when i open the door, the system doesn't give me a countdown to enter my code to switch off the alarm? (it used to do this before) Check circuit time is final and what is the entry time set up. Also what is logged when this occurs Quote WHAT MODE SHOULD THIS BE ON? i think i have set this as timed its the circuit type that will be set as finel the area setting mode will be timed 2 hours ago, kyrusdemnati said: I do have a bell box, but i need to get a ladder and learn the device again. What mode should be set too? it isnt programmable iirc it should be a tamper 2 hours ago, kyrusdemnati said: My backlight display on the device, times out so its blank after setting an alarm how do i make this visible at all times? it should do that to comply but you can change it in system displays 2 hours ago, kyrusdemnati said: Upstairs Window Back Conservatory Door what mode do i need to put this on? Intruder Quote
