HOW Posted April 1, 2019 Posted April 1, 2019 Hi - I have installed a GJD external lighting setup on a home. It has 4 zones. In the house there are two 2 zone wiring boxes and a 4 way control panel. These extend out to the garage where there is an additional wiring box for zone 1 and 2 and a remote 4 way control panel. This was all installed 2 years ago and has been working fine since. It is a great system. It has however just started causing a problem where the lights are coming on and staying on all the time. if you reset the system it will work for anything from 30 mins to 6 hours or so and then all the lights will come on usually for all 4 zones and stay on. They even come on for zone 3 which is off on the control panel. At this point if you touch either of the keypad controllers, they are locked up and just makes a strange noise. I know that there has been nothing that has changed on the install. Can anybody point me as to where the best place to start is please to troubleshoot this? Thanks Quote
Secware_Tech6 Posted April 2, 2019 Posted April 2, 2019 I would start by looking at the power supply that is feeding the control panel. What else is this supplying? Quote
