dno32 Posted February 15, 2010 Posted February 15, 2010 Hi, I am having part of my garage converted into a small room with access only from a outside door. I would like to add this room to my 9448+ by adding a new zone. Can I add a door switch, movement sensor and extra keypad to this system? also I would like to set the alarm for this room at all times even when we are in, however we part set the alarm at night arming the downstairs zones. Would it be possible to part set the alarm and the new zone or will I have to manually omit the upstairs zones at night leaving the downstairs and the new room armed? Quote
Secware_Tech6 Posted February 15, 2010 Posted February 15, 2010 You could reprogram the part set, but this panel only has a full set and 1 part set option you can add additional sensors assuming the panel has spare capacity. it will also accept additional keypads. Quote
dno32 Posted February 15, 2010 Author Posted February 15, 2010 If I add it to the part set then I wont be able to set it during the day as we will be in the house. To get around this can I omit zones and then set the alarm? i.e. during the day I omit all zones apart from the new zone 5, how would the entry/exit zone work with this? Quote
Secware_Tech6 Posted February 15, 2010 Posted February 15, 2010 i dont think you can omit the entry zone on a 9448. If you just wanted that zone on then yes you would have to omit all the other circuits. You may be better of with a more powerful panel that allows multiple part sets Quote
dno32 Posted February 16, 2010 Author Posted February 16, 2010 I would rather not get a new panel, so it looks like I will just get a movement detector and add the new zone to my part set and just set it at night. Perhaps I could get a seperate door alarm which I can set whenever we are not using the room? Can you recommend a detector and door alarm? Quote
Secware_Tech6 Posted February 16, 2010 Posted February 16, 2010 I dont know of a professional grade door alarm unit sorry. Quote
dno32 Posted March 5, 2010 Author Posted March 5, 2010 Hi, The room is now ready, can you recommed a motion detector for the scantronic 9448+? I am not sure which one would be best suited. The motion detector will face the outside door, the top half is frosted glass, would I be right to say that anyone walking past will not be picked up? Also, I will have a couple of large fish tanks in the room, I have been told these will not set off the alarm would that be correct? Thanks Quote
Secware_Tech6 Posted March 5, 2010 Posted March 5, 2010 no the fish tanks should be fine. As long as there is no air movement from them. Also a PIR will not detect through glass. example detector http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=1007 Quote
dno32 Posted March 8, 2010 Author Posted March 8, 2010 There will be air movement from the tanks, nothing big just a small tube from the filter with bubbles coming up it. Also a couple of the fish are quite big, about the side of a small plate (8") with this in mind would I be better off with a pet tolerant detector? either that or house the tanks out of sight under the detector. As the system is a scantronics would you not recommend a scantronics detector? Quote
Secware_Tech6 Posted March 8, 2010 Posted March 8, 2010 There is nothing wrong with scantronic sensors at all. I was just providing an example. with all pro panel you can use virtually any hardwired pro sensor. There is no requirement with hardwired to use all equipment from the same manufacturer. ie not all manufactures make panels and sensors, ie optex dont make a panel as far as i know. The air movement id expect from a fish tank would be minimal so i wouldnt worry. Unless its like a fan heater! There shouldnt be a need for pet tolerant sensors with a fish tank as they are behind glass. I am generalising as i havnt seen your application. James Quote
