San Posted February 8, 2008 Posted February 8, 2008 Hi I've installed the Scantronic 9651 with RKP 9940. and wired the panic button off the RKP but when i test the panic button, it doesn't work, any ideas i have two installs doing the same. San Quote
Secware_Tech6 Posted February 8, 2008 Posted February 8, 2008 Hi I assume The 9940 keypad can be connected to an external panic attack button, asshown in Figure 11. If the panic attack does not contain a tamper switch, link the pair of "EXT TAMPER" terminals. Separately link both pairs of terminals if no panic button is used. You have done the above and you will also need to enable the keypad pa option 87: Keypad Dual Key AlarmsThis command enables users to raise an alarm by pressing two keys on the keypad at the same time. Three types of alarms are available, each of which can be enabled or disabled independently. The default is disabled (option 0). Hope that sorts it for you Tech Support Quote
San Posted March 17, 2008 Author Posted March 17, 2008 Hi, I've enable PA on option 87, but still no joy Quote
Secware_Tech6 Posted March 18, 2008 Posted March 18, 2008 if you disconnect the circuit wire to the pa connections in the keypad and leave engineer mode what's the result? Quote
San Posted May 24, 2008 Author Posted May 24, 2008 Sorry the RKP is a 9941 not 9940 But i just tried a second panel with 9941 RKP and the same result, but the tamper side of the on panic works Quote
Secware_Tech6 Posted June 1, 2008 Posted June 1, 2008 SO if yu remobe the link on the keypad and exit engineers what does the display show? Quote
