colin Posted February 7, 2008 Posted February 7, 2008 I have been asked to source a replacement for a damaged BPT video intercom. ONce stripped the circuit board had the serial number VZ 110 and the video camera VT 100. The panel itself looks longer than anything in the present BPT range. Does anyone know of a direct replacement for this panel which is about 12" high. The reason I ask is that it has been mounted in a welded housing and would be a lot of work to retro fit with something else. Quote
Secware_Tech6 Posted February 7, 2008 Posted February 7, 2008 Both those parts are now long out of manufacture. We estimate its 15-20 years old? Nothing currently manufcatured will match your mounting locations but it might be ebtter to send it to us for repair. Alternativly we could custom build a new module. All this depends on the system installed as it may be more cost effective to replace it. Tech Support Quote
