Secware2 Posted April 5, 2016 Share Posted April 5, 2016 I Purchased a Galaxy Dimension panel last week. It didn't come with an installation or programming manual.I have found some information on line. But need a few answers if possible.What are the external bell box connections? What are the internal sounder connections?I have the system operating with a few detectors and the system has 1 fault which is because it does not have a telephone connection. Can this facility be turned of as I don't need this facility at the moment? If not what is the best way to clear this fault so the system has no faults and is usable. Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted April 5, 2016 Share Posted April 5, 2016 Bell ===== Galaxy Strobe + === +12v Strobe - === RIO0 Out 3 SCB T === Aux Tamp SCB A === GND Bell D === +12v Bell B === RIO0 Out 1 Program Output 1 and 3 as Bell and strobe respectivly Internal Sounder connections will bepend on the type you have. Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted April 5, 2016 Share Posted April 5, 2016 To remove the line fail disable Line voltage monitoring in the communcations menu Quote Link to comment Share on other sites More sharing options...
