Secware2 Posted April 5, 2016 Posted April 5, 2016 I Purchased a Galaxy Dimension panel last week. It didn't come with an installation or programming manual.I have found some information on line. But need a few answers if possible.What are the external bell box connections? What are the internal sounder connections?I have the system operating with a few detectors and the system has 1 fault which is because it does not have a telephone connection. Can this facility be turned of as I don't need this facility at the moment? If not what is the best way to clear this fault so the system has no faults and is usable. Quote
Secware_Tech6 Posted April 5, 2016 Posted April 5, 2016 Bell ===== Galaxy Strobe + === +12v Strobe - === RIO0 Out 3 SCB T === Aux Tamp SCB A === GND Bell D === +12v Bell B === RIO0 Out 1 Program Output 1 and 3 as Bell and strobe respectivly Internal Sounder connections will bepend on the type you have. Quote
Secware_Tech6 Posted April 5, 2016 Posted April 5, 2016 To remove the line fail disable Line voltage monitoring in the communcations menu Quote
